Leveled on stock rims and tires
If you have the Off Road Package, which comes with a 1" lift, you run the risk of popping an upper ball joint if you level with anything higher than 2" spacers. The replacement UCA's can handle the sharper angles with the increased ride height. Piece of mind when driving aggressive or off road.
Thanks Vader! VaderRebel.....good name.....NightRebel....heh. Ok maybe it was only funny in my head.
So I have a Rebel and then have the extra 1” lift right? I wouldn’t want to go past 2” spacers. Don’t plan to off road much if any, but it sounds like it’s still a safer thing to add the UCAs?
If it’s overkill then I won’t do it. But if it’s borderline then as you mentioned, peace of mind is worth it.
So 2" spacers on the Bighorn (no off road) sounds like I'm okay then... I do like how it turned out. I went with the BF K02 285/60/20.
