Guys,
My 1500 throttle seems to be asleep. I have to nearly floor the gas pedal to get this rig moving. Any of you guys experience this and what have you done about it?
To reset the Dodge Ram throttle position sensor(TPS), You need to turn on the ignition without Your foot on the brake, so the engine doesn't start. Then press the accelerator on the floor for 15 seconds. Release the accelerator. Then turn the car off and start the engine and drive
Buying a throttle controller also greatly improves things
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
