Atlantahank
Good day, looking for some help. I switched all my interior lights to LED on my previous RAM and it all went well. I did the same for my new RAM (2020 Big Horn Crew Cab) and everything appeared to work fine, all the footwell, glove compartment, dome and vanity mirrors lights work perfectly. The issue is with the two map lights in the overhead console. First they are a real PIA to change but I tested them in the garage and they worked just fine. Open the door, they come on, turn them on/off manually and they worked fine. HOWEVER... this evening I started the truck and lo and behold, they won't shut off. I read on the forums that it may be a loose fuse or connection but I checked those and they seem fine (several fused were less than tight). For now I just unplugged the connector, rear dome light works as it should but obviously no map lights. I checked the rheostat on the dash to adjust brightness as well as the cargo light and they are turned off. Any ideas or suggestions are greatly appreciated.
