LED install question
Renegade3
Northern VA
I’ve got my ram apart to put the OEM LEDs on and realized that the bottom portion (black piece that sits below the headlight) won’t work from the halogens. Looks like the heat sink is in the way. Anyone have a part # for that?
What purpose does that serve other than a place to clip in the front trim? I almost did it without that piece but don’t want to jack anything up.
knightro84
Easley, SC
The part number for the bracket is the same for the halogen and LED headlamps - so the ones from your halogen lights should fit?
Part numbers are 68432393AA and 68432394AA
RebelWraith
Polymath
Montclair, Va.
You would be the first person to have this issue. Tons of people have completed the factory midline LED upgrade using the the same headlight base that the halogens use.
Renegade3
Northern VA
I'll dig back into it, as I stopped last night. The more I thought about it, the more I think I was just tired and not looking at the base correctly.
mjtodd
I just swapped out the Halogens with OEM LED headlights on my 2020 Bighorn today and didn't have an issue. They should fit nicely.
Renegade3
Northern VA
Yeah, it was good to go I was tired and not paying enough attention. Do you know if the fog lights to LED are plug and play after reversing the wires?
mjtodd
I believe you still have to hit the BCM afterwards, but not exactly sure why. Infotainment has the install video on their YouTube channel for a halogen to LED fog upgrade and they have to do it. Glad your headlight install went well. It really changes the look of the truck for the better.
