LED Bulb Replacements
Donnybrasco201
Hi all,
I have a 2022 1500 Laramie and I just bought LED bulb replacements on Amazon (not cheap ones - they were like $60 per set) for low beam and high beams. They came with what is supposed to be a canbus decoder I think because there was a black box attached. Regardless, they work for 3 seconds when I turn truck on then shut off. I do see an error type thing on dash which I presume means there isn’t enough power.
Bottom line - can someone PLEASE recommend LED low & high beams either on Amazon or somewhere else that are in that $40-$60 range per set. That WILL work with this stupid canbus crap. Thanks a ton!!!!
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Hi all,
Off the shelf LED bulbs? Most likely not going to happen.
Just to switch in and program the OEM LED`s to the BCM takes a SGW bypass and alpha OBD to the tune of hundred plus AFAIK
