@tommyxv you'll need a whole fuel rail. I wouldn't chance splicing in a piece. I can check in my garage later, I might have a 5.7 fuel sitting in there. You can have it for shipping if you want it
Yes, a stream of fuel is shooting out of the hose when it's running.is it even leaking? most fuel lines in the engine bay are braided, some braided with a rubber hose or rubber surrounding it. looks like just the rubber outer portion is damaged.
Need hose rated for fuel injection, regular fuel hose has a low psi rating.Two barbs, piece of hose rated for gasoline and four hose clamps for a temporary fix.
That's exactly what I did. Hose and clamps are both rated for use with fuel injector systems.Need hose rated for fuel injection, regular fuel hose has a low psi rating.
