AC line is easy to swap. removal of airbox is recommended to make your life easier.
just some 10mm sockets (and probably 13mm or something, forgot exactly which ones... i just did mine right after Labor Day) and you'll be able to swap it. You'll need to find a place to charge the AC though.
before you do any of that, is your AC still cold? is that "leak" green colored?
when i busted my AC line (i documented that in one of the threads on the forum) it was green to the naked eye and not UV. mine's a 2022 so maybe it's different.the factory put's uv leak detecting dye in a uv flashlight will make it glow
Loading…
www.amazon.com
