Leak issue
royP
California
Hello guys, I think there's a leak in this pipe. What should I do? Can I fix it myself? Should I take it to a dealer?
that's a A/C line, i doubt you can fix it yourself. first i would clean the motor then confirm it's actually leaking.
AC line is easy to swap. removal of airbox is recommended to make your life easier.
just some 10mm sockets (and probably 13mm or something, forgot exactly which ones... i just did mine right after Labor Day) and you'll be able to swap it. You'll need to find a place to charge the AC though.
before you do any of that, is your AC still cold? is that "leak" green colored?
the factory put's uv leak detecting dye in a uv flashlight will make it glow
when i busted my AC line (i documented that in one of the threads on the forum) it was green to the naked eye and not UV. mine's a 2022 so maybe it's different.
or i have UV vision LOL
