Lasfit LED Fog Light Issue
Tomt
I installed both Lasfit fog and high beams. When I engage the highbeams, the right fog light goes out but the left fog light remains on. Any ideas? Both fog lights work properly when high beams are not engaged so I believe the polarity is correct.
They drop when HB engaged.
If your steering wheel is not centered, it will aluminate the side the steering wheel is pointing to. This feature is to help with lighting up turns.
