Laramie rear seat question
jsimon26
I recently swapped in a full Laramie seat set into my Big Horn. I have a question on where this flap goes behind the middle flip down seat/arm rest of the rear seats? Looked around and couldn't find an obvious place.
Eighty
Moderator / Dream Killer
Mine is a TRX, but probably the same as other trims. Since you have a Bighorn, it might just be missing the catches for the flap.
6of36
Michigan
The texture looks different in the two trucks. To me it looks like they put a nicer panel in the trucks that have the fold down arm rest, and it has those attaching points.
Pooch
Does Laramie rear seat doent fold? Been trying to access my HK subwoofer but I cant find the string for it to fold
Lpsouth1978
My Laramie rear seats fold. Do you have the reclining rear seats? My understanding is that the relining rear seats fold, but the stationary seats do not. Don't quote me on that though. :)
Eighty
If yours does fold, the pull strings will be situated like this. Easiest to reach from the center (if you have a folding center armrest).
jsimon26
They fold, the string is pretty hidden on each side. Reclining the seat helps access the string a little easier
6of36
Michigan
In the year and a half I had my Laramie, I didn't know they folded.
Eighty
Unfortunately, it's not very useful. I couldn't get mine to lay down flat - they just lean forward a little. Not sure what good it really does.
Lpsouth1978
I use them for behind the seat storage. This is where I keep my battery powered inflator and jumper cables.
