JeffJr
These headers and green cat y-pipes are amazing and are very good quality. My buddy and I put them on Saturday and wasn't too hard. Started at 10:30 am and finished by 2:30 pm, so about 4 hours total. The most time consuming part was putting the bolts and tightening them on the headers. Took about 30 min to remove the stock exhaust manifold and y-pipes. The only hard part was tightening the bottom middle header bolt on the driver side. Super tight area to get hands in and patiently tightening it little at a time. Also I decided to use the stock header gaskets because of the extra heatshield material and cause the truck is brand new, but probably should of used the gasket that came from kooks cause the stock gasket made tightening the bolts harder cause of the lack of space to work. After the headers were installed the rest of the pieces were easy to install and was a breeze. After the install it definitely made the truck sound even more alive accompanied with my Mopar cat back exhaust and Mopar RAM Air cold air intake. What's even better, no tune or modifications needed, everything was bolt on. No check engine lights and the truck drives even better then before. I will post a short video on YouTube after install sound.
