Apologies if a thread like this already exists. I decided to go digging to see if I could find any TSBs on common issues I see posts about and below is a list of what I've found (I've bolded key words in some of the less specific ones).
- The customer may describe popping or cracking noises heard around the front floor or A-Pillar area, while turning left or right (during a lateral movement).
- There is a loud clunking noise from the front of the vehicle.
- The customer may comment on the following: A high pitch “squeal” originating from the rear brakes, often occurring in cold, humid weather and when driving in reverse, after the vehicle has been sitting for at least a few hours. Very often, the noise can be heard in the morning, when backing out of a driveway.
- For AC Refrigerant Low pressure, AC blows warm, Not Cold, not cold enough, there is an investigation for a low charge on the HVAC diagnosis.
- The customer may describe one or more of the following inside the cabin: A drone noise. A booming sound. A humming noise. A muffled sound. A pulsing noise.
- Customers may experience one or more of the following: Exterior mirrors do not return to the original position after shifting out of reverse gear. Exterior mirrors continue to tilt downwards even after shifting out of reverse gear. Automatic window express-up/down (driver and/or passenger) operation continues after an engine start without customer pushing/pulling the switches.
- The customer may notice when closing the rear (one or both) windows: One or both may bind when closing. Squeak/squeal noise when closing. Pinched or rolled seal. Wind noise when driving.
- Whistle Noise Inside Cab With Window Slightly Lowered.
- Water Leak Rear Of Cab Rear Seat Or Headliner.
