knock
shane1981
I'm at 1500 miles and just noticed a possible knock. when I crank the truck up on a cold start there is absolutely 0 noise it runs smooth and quiet but if I put it in gear it almost sounds like it has a knock it's not too loud but very noticeable but goes away after it warms up but keep in mind it does not make this noise until put in gear anybody have an explanation?
We certainly understand why this would be concerning, shane1981. If you decide to address this with your dealer, please be sure to let us know via private message. We are more than happy to escalate a case on your behalf and connect you with a case specialist for an additional layer of support through that process.
Mark
RamCares
2019 bighorn dt. I have the samething. Thought it was normal
run two or 3 tanks of 93 and let pcm adjust. you will notice a difference. I did.
