D - Firm order. Your order now has a name instead of a number: A VIN! Materials should have been ordered by this point if all goes well, you should have a truck.
D1 - The date is set for your truck to be built. The plant knows when it should have parts sequenced for building and it should start to be built within 48 hours of the date set.
D2 - It's going to be built. The
computers are being programmed, materials are being sequenced, framing is about to occur.
E - Frame. Metal is welded together to form the body and frame. The body is inspected at the end of this step to ensure it's within tolerances.
F -
Paint. The metal is coated, primed, sprayed, clearcoated, polished, inspected, and hand finished if necessary.
G - Trim. The engine is installed in the chassis, the interior is installed, the
chassis is mated to the body, the bed is put on. At the end of this, your truck is built.
I - Inspection. Your truck goes through a
battery of shakedown tests and measurements are taken to ensure the vehicle looks and performs as expected.
