Just ordered ReadyLift 3.5", What Wheel size?
Kennydoyle
AS the title states i just ordered a 3.5" lift from ReadyLift. I was wondering what size wheels I can run with this setup. I know the website says 20x9 0 offset but I have seen different setups posted all over the forum. I was hoping to run 20x10 -18 offset with 35x12.50xR20 tires. Will I experience rubbing with this setup? Thank you all for the help!
Kennydoyle
Do you know this from experience? Doing some research I found a photo and description of a truck that has the same setup and owner says there is no rubbing and he did no trimming. But that’s the only one I’ve found
Tac747
35's will fit without rub unless the suspension is in articulation. An example would be full left turn backing into the driveway and when the left rear tire climbs the curb the right front will rub. I wouldn't even want to see what would happen off road in a hard turn.
Tac747
So basically.... they rub.
Short answer-Yes
Long answer- Depends on if you use it as a truck. If you only drive it on paved surfaces you should be fine but if you take it off the pavement I would recommend not putting 35 on anything less than a 5" or 6" lift. Thats why I just stuck with 33" tires. I use my 4 wheel drive.
Kennydoyle
Short answer-Yes
Just had to heat up the plastic liner and push it back about an inch. No rubbing whatsoever on or off road
