I did a negative terminal battery reset and that got rid of the initial pedal lag that I had when I picked up my truck from the dealer.
30 seconds....big difference... enough where Im not going to waste money on the pedal commander. By the time I put on my CAI and cat back Ill be good!I am going to don't at the day In pick up mine. How long did you leave it disconnected for? How much of a difference did you notice?
Just made a install video for the pedal Commander for our trucks. very easy but if y'all want a visual before you try to install here it is.
That's sounds like the same spot I put mine.Where did you mount the pedal commander I stuck mine under the dash on the center console. Stuck it on the flat area just behind the upper console.
