Is this the correct part I need to fix my paroblem?
MValdez
North Wales, Pa
Yesterday ,I parked my trucked, turned it off , and immediately My driver side window retracted as if the sensor was activated and went dead. Could not put it up or down. All other windows and door functions work fine. There is no noise when hit the window up/down button. To test if it was a window motor regulator I activated my windows auto up/down feature on key fob ( Tazer td) and only my passenger side window would work. Is the part in the picture below the the part I need to fix my issue and if so could someone help me with the part #?
BowDown
Frisco TX
Most likely if you're not hearing a noise.
If you hear a noise yet no movement, the regulator has broken.
Window Motor - Driver's Side (LH) - Mopar (68321289AA)​
mikeru82
The Palouse
You might want to test the motor before replacing it. A wiring issue or bad switch could also cause what you described. While the motor is the most obvious culprit it's not the only thing that could cause the problem.
