Willwork4truck
I’ll give you 50% of value and take it off your hands, if you show a new oil change receipt so that when driving away it doesn’t self-destruct.
Seriously, don’t you think this and the other RAM forums would be screaming about this if it was a big issue on the 2016 and up?
Believe about 10% or less of the horror stories and just enjoy your truck.
Every brand has flaws, some engines might be a little better/stronger but then that brand will have tranny, rear end or suspension issues.
Talk to mighty Toyota, a good 5.7 motor and a problematic rust-prone frame (Toyota agreed to a massive $3.4 billion settlement for owners of the 2005-2010 Tacoma, 2007-2008 Tundra and 2005-2008 Sequoia.)
Nissan had rear axle seal failures necessitating a whole new axle from about 2004-2009, but the motor was good.
GM, well lets just say that the 5.3 has had it’s ups and down on oil consumption (2007 AFM ring to cylinder wall clearance) and their 8 and 10 speed trannies have had software problems plus the 2014-2016 wind buffeting/shaking issues drove owners bonkers.
Ford had problems with oil consumption on the later 5.0’s and turbo failures/valve coking on the earlier ecoboosts.
So the hemi has a tick, oh well. Have an extended factory warranty? Maybe you should if you are worried. These are all mass produced drivetrains, some with engineering issues that can be fixed, some you just live with until you can’t or decide something else is prettier.
What are the odds you will keep your truck to 150-200K anyway? Me, the vehicle is gone within 6 years just cause’ I have this idea that something is better...
