iPhone 15 pro compatibility problems with uconnect5
turboramjet
Bloomfield MI
I am able to connect my phone (iphone 15 pro) to the truck (2023 Ram 1500 Laramie) it works well for a while., but then after parking for 30 minutes and restarting the truck, the phone won’t fully reconnect.
the recent calls don’t display, and the messages don’t display. Screen show phone is connected.
Sometimes i can turn bluetooth on and off on my phone and it will fully reconnect, other times i get an error message stating phone is not compatible.
Any one else having problems? Or have a solution?
My iphone 15 pro is working now.
I enabled show notification slider in setting bluetooth unconnect
with show notifications off i get a feature not supported pop up message when selecting messages when on the phone app
Sascwatch
I havent used the Uconnect/phone integration much, but I have had only minor issues recently using CarPlay on a few different iPhones.
One issue I have is if I go out and start the truck my phone connects and CarPlay starts up. But say I forgot something and went back into the house my phone will disconnect and from sometimes it won’t reconnect without either restarting the truck or phone. It’s hard to say which end the issue is on as I have no other vehicles to compare it to.
Another issue, which has been nearly resolved by over the air updates is disconnects caused by interference in a few small towns I pass through from time to time. The connection cuts in and out until it drops completely unless I can get out of the problem area quickly.
If I physically connect the phone and disable wireless CarPlay these issues are gone completely.
GMetal
I have had that happen. I ended up restarting the phone and the radio. Once I had to delete the phone from the radio and re install it.
