I'm in the process of converting my interior lights to LEDs and was wondering what size the interior dome light is. I've seen references on here to 41mm but the Lasfit site is showing 44mm for the 2021 RAM. Diode Dynamics has a 41mm festoon but their 44mm has wire/loop contacts which obviously won't work.
Also, what is the best tool to use to remove the map light lens covers/diffusers? I don't have anything small enough to fit in between the lens and the housing without damaging either. I tried over the weekend to remove the housing itself by removing the two front bolts that anchor it to the roof. I was able to get the two front clips free but I could not get the back clips free. I was very afraid that I was either going to break those two back clips or damage the headliner with the amount of force it felt like it was going to take to get those back clips off.
At this point, if at all possible, I'd like to just pop the lens covers off.
