So this morning before I left I decided to use a eye cleaning wipe to clean up some dust on my instrument cluster on my 19’ ram. After taking a couple swipes I noticed that it put some fine scratches on the instrument cluster. The sun was shining directly on it so it was easy to see. I tried using a soft microfiber to clean up the fine scratches and was unable to remove them. Has anyone had any experience with this? I called Meguiars and they recommended using their PlastiX product. Is the instrument cluster shield plastic or Polycarbonate? I probably will end up living with it since trying to remedy it may make it worse. Is there any solutions that will remove fine scratches without making it worse?
Thank you
Dan
Thank you
Dan
