Install Video
jayram2875
People say there is a video on installing the Daystar leveling kit, I am curious about disconnecting the air bags.
Had mine at shop today and shop foreman said he needed to get a interface cable to plug in to system so he could shut it down.
He said the bags are under high pressure and did not want to disconnect them well active
Jmaloneydo
What is the part number of the daystar kit you are going with? I have a limited that took into a local shop and they called daystar and said that nothing is compatible with our 2019 air ride suspension. I know others have done it. I just need the part number. And from what I've heard only the line is under pressure and you can disconnect it up to 3 times before you have to re pressurize the bags supposedly.
jayram2875
Jmaloneydo
Thanks my friend. Let me know if you get it all worked out as I would like to get tje daystar spacers put on as well
Samson75
Samson75
I just put the spacers and made my own sensor links for less then 20 bucks! Use threaded rod 10mm (stainless is best). Use M6 snaps 10mm x 1 . Picture shows example. There is a video online YouTube . I used it and it was the best tool ever however the link length was wrong. Steal that from the Revel site! Limited tools (must have torque wrenches)
Here is what I got from the revel site. It worked for me perfect. Each thread on rod is 1mm
1. Look straight inside the wheel well & you will see the factory ride height sensor Link.
2. Simply twist & pull the factory Link off.
3. Shortening the Link from the factory length will raise the vehicle. Each 5mm variance from stock will adjust
the vehicle approx 3⁄4 - 1”.
4. Connect one end the Adjustable link to the sensor and the other end to the frame.
