O Captain My Captian
- May 2, 2020
So I thought I'd take advantage of the lovely weather we had yesterday, and installed a front and rear dash cam. I have to thank other forum members who posted their experiences and ways of installing and hardwiring accessories in their Ram trucks. The support provided by BlackBoxMyCar.com (where I'd purchased the camera) was really informative as well. It really made this process easier. I hadn't come across any description or "how to" for the 2020 Ram, so, in the spirit of paying it forward, I'll try to describe my process and how I achieved my result.....which worked out very well.
The BlackVue cameras can also be bought with a Power Magic Pro box. This device supplies power to the BlackVue cameras from the truck's battery according to the configured voltage and timer to prevent vehicle battery discharge. You can then have your camera "on" after you park for a programmable time and/or threshold battery voltage, without having to worry about killing your battery. This needs to be connected to an always active fuse and an inactive fuse.
I first started by exposing the fuse box located behind the knee bolster. A 7mm ratchet was used to take off the two bolts and then I used a trim, removal tool to gently pry off the panel. There are 5 small clips that hold it in place. There is no cover for the fuse box.
I then looked for the active (or always on fuses) and the accessory switches (ignition-activated) fuses. Using a simple "Test Light" I found the following fuses to be always active. I chose to use F33 (3rd pic below)for my active connection.
There were two inactive fuses that I could have chosen from as well, and I chose F55.
I could have used an add-on circuit but as I only had one on hand, I just decided to run the wire alongside the fuse.
I then went about getting the wiring for the cameras in place.
For the front camera, I decided to install it below the rear view mirror box. This would not be readily visible from the inside of the truck by either the driver or passenger, and was still high enough in the windshield to give an expansive view of the road in front.
Using a trim tool, I loosened the casing around the rear-view mirror. I then placed the camera-end of the wire in with some slack and began to run the wire along the top, tucking it into the headboard using my fingers and trim tool. It felt like there was a small lip that the wire could settle into.
At the A-pillar junction, I exposed the space by pulling down the weather strip. I ran the wire down trying my best to avoid interfering with the airbag.
