chrisgrashorn
- Nov 1, 2021
Hello, I'm running into some trouble installing the Air Lift 1000 in my 2019 Laramie. All of the instructions and videos I can find show a large space for the air line to go through the top of the spring. On mine I have a bolt going through some metal parts at the top. I removed the bolt from the bottom along with the piece that was on top which leaves enough room for the air hose but I'm not sure there is enough clearance for the top of the air bag once the spring is compressed. Is there some sort of aftermarket spacer installed here? If so, what is it and do I need to remove it in order to install the bag? Trying to avoid pulling out the springs if I don't have to. Thanks!
