Install factoy sway bar bushings
Myersc
I just purchased factory sway bar bushings for my 2019 Ram Rebel. These bushings aren't split with an opening to put the bushing onto the sway bar. Am I supposed to make a cut in the bushing so I can place it on the sway bar? Or do I have to undo the sway bar link and push the bushing onto the sway bar (which I don't even think will be possible...but maybe.) Thanks.
Factory bushings are split. Hellwigs are too. Won’t hurt to make a cut. Maybe they forgot.
Mine weren’t split. I just slid them off the ends and slid the new ones on.
I would slice them with a sharp razor blade and clamp them down. Works for other bushings, it will work for these.
Just buy energy suspension bushings that are better than the factory ones. They do come split
I made the cut and did the install the other morning. The truck is silent now! If a dealership tells you to install end links and bushings which mine did do the bushings first. I also bought rear bushings but haven't installed them yet. The new ones are cut. As for the comment above about purchasing aftermarket ones, I'm not sure it's necessary in my opinion. I have 75,000 kms' on my truck so if the factory ones get my another 75k I will be happy, though I doubt I will have the truck for another 75k.
People go aftermarket polyurethane bushings because they are more solid and allow the sway bar to work better.
Fellas, just as an FYI, I've replaced sway bar bushings on two separate 5th gen Rams already, and what I've learned the second time around, is Do NOT buy Moog aftermarket bushings. Just buy the OEM ones.
Whereas the OEM ones seem to last 60,000 miles or more, my truck was clunking worse than originally, after just 1000 miles of use on the Moog bushings.
It's hard to believe, and if you got under there and checked with a large prybar, they weren't as obviously shot as the OEM. However, I bought OEM bushings(not split) and tried it anyway, just because I was sure the sound was so familiar.
Also, as mentioned by others, even though the end links are known issue on these trucks, each time for me, it was the bushings that were the culprit.
Did you get the blue moog bushings or the black?
Where did you make the cut on your oem front factory bushings to install them on the bar? I bought oem ones after the energy ones I used continued to squeak even after greasing.
I went ahead and looked up the OEM method to install and it said use soapy water and push through. Seemed to work well instead of cutting.
The bushings are not
Split but easy to install. Take off the top link nut and two bushing bolts pull the link out and drop the bar down a little. Remove old bushing and install the new bushing by squeezing it with a pair of channel locks so it fits over the end of the bar. Once it's started but the bushing bracket on with the bolts turned by hand, this gives you leverage to pull the bushing on by hand the rest of the way. Once it's on the round part take the bracket bolts back off and slide the bushing into place and install brackets over the bushings.
