SupremeWill
I really like the lowered look. I want to do a 2 / 4 drop.
The Inez kit is nice but a little expensive. I called BellTech and they are developing a kit with no idea when it will be available.
I think that you can change the front coils only to achieve a 2” drop in the front without having the change the upper/lower control arms.
What I can’t believe is that there isn’t a coil already out there that meets all the current front coil specs such as wire size, ID, OD, spring rate but 2” shorter.
Has anyone looked into or researched that.
Appreciate your input.
This was possible on the 4th gen trucks but not on 5th gens. The new trucks have a strut in the front. So you can't just simply swap out the spring.
