Ortiz7983
- Nov 6, 2018
My stock tire size is 285/45/22. I’d like some more sidewall on my new tires. I have stock suspension on a Laramie crew cab 4x4. Am I able to install 285/50/22 or even 285/55/22 tires on my truck with out rubbing it anything? I’ll be using the same stock rim as well so the width and wheel size numbers stay the same. I believe the 50 is 1 inch taller and the 55 is 2 inches taller. Going with some Nitto Ridge Grapplers.
The image shows my truck with Nitto ridge grapplers 285/45/22, stock size. I want to go with the same but taller side wall.
