TheFoodMan52
- Mar 26, 2024
Roger. I'll get my pry bar and check the sway bar holes tonight, and make sure the tips are cut. I've got some fresh cutoff wheels and grinding discs so I'll be good there.jajajaja man I feel you on the bad roads, I live in Sh!tvannah Ga for now. Running through SC on 95 is a poor choice for any vehicle.
One of the things to check is the hole the sway bar end links go through on the IHC lower control arm (I heard they fixed it) the ID of the whole is to big for the sway bar link (also check if they cut the thread shorter on the link so you can properly tighten it down) I had to make a hat bushing to take up the difference.
To stop the sway bar from hitting the springs I took the sway bar to a heavy equipment repair shop that does truck springs and had them slightly spread the sway bar open. It clears the springs by 0.1500" - 0.2000" so that is good enough for me.
I'll check the sway bar clearance again as well and get a picture for ya.
