I just added the OEM power running board !!!
I don't know about the wiring harness, E in the picture, but the connector, F in the picture, can be ordered from Mouser Electronics. I tried ordering the connector through a few dealers and it was only available as part of the larger wiring harness for a few hundred dollars.
Gray: https://www.mouser.com/ProductDetail/Yazaki/7283839840?qs=yqaQSyyJnNh9MpXEI9L1Sw%3D%3D
You can also order the black connector that is part of harness E in the picture, from Mouser if you needed too.
Black: https://www.mouser.com/ProductDetail/Yazaki/7283859930?qs=yqaQSyyJnNiHvKWDU4HgCQ==
Did you end up making your own harness up?
No, I bought a used set of boards and the seller had all the harnesses but didn't have the gray connector.
Ah ok. Yeah i couldnt pull any of mine off since they were made into the oem harness.
Just installed these on my 2022 Laramie 4x4. The install was pretty straight forward. However, once I finished they didn't work correctly. They are attempting to work. I can see and hear them move. The problem is they are not coming down all the way. Also when I open the drivers side door the passenger step deploys and when I open the passenger door the driver step deploys. Lol. And like I said they are not fully deploying. I think that I have the wiring to the grey clip mixed up. Did you install the wires to the grey clip: brown/orange, orange, green, green/brown? And the running boards were fully assembled out the box so I just bolted them up. I saw one YouTube video of someone manually extending the steps prior to installing and connecting. Not sure about that though. I've attached a photo of how mine looks. I'm pretty sure the black clip wiring is right (the orange wire is directly underneath the red). Any input would be greatly appreciated.
where did you find em at, i have a 2022 and wanna put the oem ones on but cant find em anywhere. mopar's site only has the boards not the full kit
