I did it again. Homelink Button Breaks
Dmalonecentral
So I am not sure if I’ve set a record or I don’t know my own strength. I have now broken 3 different Homelink buttons in 2019 Rams. 1st was a 2019 Limited, 2nd was a 2019 Laramie Loaner (that I had for almost a month), and now my 2019 Laramie. I pressed the button just a little bit ago and garage door didn’t close so like the IT guy in me I pressed a little harder and SNAP. Just like the previous 2 I’ve broken it still works but I had my 2016 for 2 years and that never happened. It anybody else breaking these buttons at an alarming rate?
Dmalonecentral
And to be clear I didn’t think I pressed the button with such force that it should have broken whatever snapped in there. It seems to me that they used some very cheap plastic on those homelink doodads.
Dmalonecentral
Well, if you ever want to break your homelink buttons here is a 2 minute video. It really only takes a couple minutes but heed my advice, pushing harder does not make it work better.
https://homelink.com/ram
fact mechanic
Yep. Same thing. Now it’s sunken in just a little bit. Still works, just feels different.
Dmalonecentral
Right! No one would probably notice but me it it ticks me off every time and it doesn’t line up the same.
Jtr
Illinois
Well, my button is receded. I don't press it too hard but I have to go in and out of the garage A LOT due to my job and kid duties. So I suspect more of ya'll will notice this over time. The button is certainly not as responsive as it was when it was brand new. Once an easy quick strike of the button is now maybe two or three. I'll wait until it completely gives out until I try to get it replaced. It is the left button below:
28472
jdmartin
Southeast
I don't know. I just press it once easy and release and the door opens. No breaks so far 6 months in.
Diamondback
Midwest
and the vehicle responds, " Successfully Opening the Garage Door after 1,000 clicks - Have a Nice Day"
and just to get even, as you try to pull in or walk in if your Rig is too large, the door slams shut on you .. :)
or
as you start pressing harder and harder, "OH! You meant THAT garage door!"
