Hello all. I had a bad battery cell in my 2021 so I had to replace it. The bad battery apparently started throwing codes and I cant clear them via AlfaOBD so I figured I would do a hard ECU reset. I disconnected the battery and attached the + and - leads together overnight but that did not reset the ECU. I then tried to reset thru Alfa but that did not work either. Ideas greatly appreciated.
