JJRamTX
Ok, I know that the A/C issue has been beat to death but after doing the clamp and getting 37 degrees air, I am realizing that the real culprit with my truck is the power and speed of the fan to distribute said cold air. I know it is Software controlled and I may just need a newer Software update to fix this but has anyone else noticed this? My fan has a higher speed on Auto (which still is not enough airflow) then being on setting 7 which should never be the case and it also is way weaker than my Toyota, Ford, Honda, and other Rams have been. I have changed the in cabin air filter three times and it has never gotten faster with that change so I know it isn't the air filter restricting it.
