Max tow has actually gone down vs the tried and true hemi, but you'll still be able to tow > 8000 pounds which is pretty much maxed out for almost every half ton pulling an RV.
I found it pretty interesting too that they rate the SO at 11,560lbs. and the HO at 10,740lbs. Obviously configurations vary those both, and that's their base model comparison, but... interesting nonetheless.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
