Humming sound underneath driver side
Frankejr74
Has anyone had the issue of hearing a loud humming, vibrating sound coming from underneath the cab. It's happened to me at least 4 times since I've had the truck(July 2018)
The sound(humming,vibration) starts up when I've turned on the truck and gets louder the more I rev up the engine. I figured out that by turning off the engine for a few minutes and then restarting it the sound goes away and it won't come back for a long time. Like I said, it has only done it 4-5 times since July of 2018 but it is annoying not knowing what the heck it is.
Thanks in advance for any and all info.
I get something loud and buzzing but it’s from the air conditioning seat when it first turns on. Lasts about 10-15secs
I'd wager the Active Noise Cancellation is malfunctioning. There is a TSB to correct the issue
Edit: TSB-08-033-19
Hi @Frankejr74 - If you're not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please let us know via private message. We would be more than happy to provide you with an additional layer of assistance for that process.
Mark
RamCares
