Darksteel165
I had the problem of the driver side MFT door not staying open at 90 degrees and hitting me in my back while loading several times.
When I went to my local large dealership the tech explained he has never seen or worked on an MFT before and the service advisor informed me that they "don't sell trucks like mine" (2022 Ram 1500 Limited).
Instead of having them monkey around with my truck I took the MFT apart myself to see what was going on.
TLDR: my problem was something was either to long or too short so the 2 metal balls inside of a plastic grommet would never be able to traverse to the last notch on the metal bar causing it to "lock open"
Step 1 remove the Bedliner panel to expose metal panel (10 push clips)
Step 2 Remove Metal panel 2 push clips and 6 T30 screws
Step 3 remove the 1 10MM screw from the MFT hinge area.
Step 4 remove the 2 10MM nuts from MFT door
Step 5 "fish" this device out of the tailgate
Step 6 expand the device on the rod all the way out to what should be considered "90 degrees locked" be careful as you don't want your fingers to get caught
Step 7 reinsert the device\rog into the tailgate and work on getting the 1 10MM screw to line up with the hole when the tailgate is opened to 90 degrees.
I ended up using 4 washers for it to line up as rod was going way past the hole it was suppose to screw into
Reverse uninstall procedure. You can test the door once the 2 10MM nuts and 1 10MM screw is installed for a proper fit.
Hopefully this helps people that have this problem and don't want to let the service department learn on your truck or outside of warranty.
I'm not sure what could even be replaced to make it fit as none of the parts appeared to be damaged.
