How to: Hook up light bar to highbeams
Dukem258
So you got everything set up and installed and have no idea how to control it using your highbeam switch. This guide shows how I have it installed on my '21 rebel.
Got it installed on my front license plate mount. I live in Alberta, Canada so i'm not required to have a plate for the front.
Where I put the on/off switch.
How I got the wire through the firewall of the truck.
The headlight connector is just one plug with a bunch of wires coming out of it like so. I'm using the driver side headlight plug in this case as it's closer to the switch relay and battery.
Long story short; get yourself a splice connector and splice it into the large white wire with green stripe onto it (There is a large and a small white wire with green stripe.) Make sure that when using the splice connector that you install it properly to get a solid connection or you may have to do it again.
20210416_000834-jpg.90171
If done so properly you can now use the highbeam switch stalk to turn on the lightbar and highbeam at the same time.
made the connection in the same way. while I installed a 280W 2-row beam. I am waiting for the receipt of 320 W 2-row. Behind the radiator grill. connected to the high beam through a relay and a fuse.
