Be sure to put it in Jack mode before lifting in the center console. Otherwise the AFIT sus will try and compensate to keep the wheels on the ground.and I mean lift the truck on a lift that i have in my garage? I havent done it yet but the time is coming?
whoops...I meant to say select ON!! then the truck can be liftedDamn I didn’t even know there was such a thing as “tire jack” mode. Thanks all, I’m learning all the time!
go into the "settings" on your screen, then go to suspension, then select "tire jack" mode, then select "on". Now you can lift it up.
oh yes...sometimes when I get in my truck it will actually adjust BEFORE i even hit the start button. ( and NO, I'm not that heavy lol).Soooooooo the air suspension system is active even with the ignition off?
Yes and my truck tried to self level with one corner lifted up with a floor jack, while tire jack mode was enabled.Soooooooo the air suspension system is active even with the ignition off?
