RiverRacerX
- Oct 15, 2018
For reference, here is what 33x12.5x20's look on a 2WD Limited with air suspension. It has room for days!
35’s fit just fine. No trimming either. Zip tie the liner away from the wheel. Like this:
Seems simple enough. Did you have to add thick back spacers to the wheels?
No spacers. I do have links installed, raising front by an inch and a half. BUT, even before links, folding the liner away fixes the rub situation.Seems simple enough. Did you have to add thick back spacers to the wheels?
Can you post some pics? Trying to decide between 35s on 20” or 22“ wheels.
View attachment 13957View attachment 13957View attachment 13958View attachment 13959View attachment 13960View attachment 13961View attachment 13962View attachment 13963View attachment 13964View attachment 13965View attachment 13966
Raising the front by 1.5" does interfere with air suspension a bit. in the Off Road 2 setting, the ride is super bouncy, and it got stuck in that setting. I had to pull the fuse to reset. Other settings are fine. Otherwise the ride is the same as factory. There is a bit more humming from these tires, at highway speeds, but just a little bit. My wife did not notice. What is noticeable is how much better the truck looks with proper tires. Stock Eagles belong on Civics, IMO. I am sure gas mileage is affected, but since it's cold here, and I am using remote start a lot, I can't really say. Truck did feel a bit sluggish with these tires. But that was compared to my 16 Rebel, which had shorter gears and smaller tires.Wow... that’s looks great! How does it ride? What effect do the links have on the ride? What effect do the tires have?
I really do think so. These Nittos are really good tires. They look so aggressive, and yet they don't produce any of the artifacts of the aggressive tires.So in normal mode you think she’s as smooth as factory? That’s very encouraging!
Great news. Others have commented that the links made the ride much worse. How did you decide on the the ridge grapplers? I’ve been looking at the terra G2s since they seem to have the reputation of being even a little more comfortable that the ridges.
I can see the ride getting bouncy, if you raise too much. Air bags, when inflated past factory specs will become stiff. I just wanted to level it. The rake was just too much for my taste. Initially I wanted the same tires I had on the Rebel - Toyo Open Country, which I really liked. But, Mopar deal of "buy 3 get 1 free" specifically excluded Toyo. I chose Ridge Grapplers based on how they looked, and reviews I read about them, which seem to be stellar.
Thank you. You’ve been very helpful. I started out wanting 22s but was concerned I couldn’t fit 35s, and anything smaller wouldn’t give me the sidewall look I wanted. But after seeing a Laramie on 35/12.5/20s in person today, I decided that was too much sidewall for my taste - a little too “off road” looking. I think my quest is over. Thank you.
Sure. I will measure and post later tonight.Bronenosets - if not too much trouble, would you mind putting a tape measure on your tire and telling me what your side wall measures? Trying to to do some real-world comparisons. Thanks
Does anyone know what the backspacing is on the stock 20" Limited wheels? I'm looking to get the pro comp 41 Series Phasers and they have 4.5" or 5.5" backspacing. I'll be going with the Nitto Ridge Grappler 35x12.5x20
I love the 33's. I didn't want 35's. No spacers required, but the clearance is tight at the upper control arm.
I was wondering if you still were happy with your truck setup. Any new issues with the air suspension?I can see the ride getting bouncy, if you raise too much. Air bags, when inflated past factory specs will become stiff. I just wanted to level it. The rake was just too much for my taste. Initially I wanted the same tires I had on the Rebel - Toyo Open Country, which I really liked. But, Mopar deal of "buy 3 get 1 free" specifically excluded Toyo. I chose Ridge Grapplers based on how they looked, and reviews I read about them, which seem to be stellar.
