Homemade Bed Divider
riccnick
Southwest Florida
I did the same thing in my Tundra, literally just cut a piece of pressure treated 2x6 and slapped it in there. Well it turns out the Ram's bed is slightly wider, so I cut a piece of coolant hose in half, and screwed it onto either end of the board to make stiff but flexible spacers, and then slid that baby in the slots. It keeps the 200lbs or so of tools in front of it in place without issue.
SPYvSPY
Arlington, TX
Decided to just make my own bed divider. I call it the:
Bed Organization Adaptive RAM Divider - HD or the B.O.A.R.D. from Home Depot.
Outstanding! Going to do this soon but may wrap it in carbon fiber vinyl and add your "Bed Org....." to it as "branding". Did you use a jig saw for your holes or a hole saw?
V8Spock
A carbon fiber wrap would be bad***, Spy! Please post pics.
I used a 4" hole saw with a drill press.
Total board length for the 5'7" bed with Mopar drop in liner was 66.5".
Drilled the center hole and then worked outward with the next hole 3" apart edge to edge.
Routed the edges.
Also, rounded the bottom corners so it wouldn't tear into the bedliner.
It's a fun Saturday project!
