RSConsulting
(sorry in advance for the excessive CAPS - I am TIRED AND PIZZED OFF)
So - WHY did they have to put the SOS button RIGHT NEXT TO THE INTERIOR LIGHT BUTTON?
It his SOS once about a week ago - and it never connected. Tonight it dialed and WOULD NOT CANCEL. Said "Call Must Be Cancelled By Operator".
Only problem - it RANG FOR TWENTY MINUTES AND NO ONE PICKED UP.
If this had been an ACTUAL EMERGENCY - I'd be typing this post FROM HELL (cause that's where I'm going to end up, according to my 3 ex-wives - but I digress).
At any rate - even with the truck shut off and locked (sleep) - the CALL STAYED ACTIVE. So rather than go to sleep, and wake up to a DEAD BATTERY, I drove home and pulled the negative battery cable - CALL ENDED.
And while I expected my settings to have to be re-programmed - I DID NOT EXPECT that many features on the truck ARE GONE.
No Choices for USB in Media
Controls ONLY GIVES me my Mirror, and not my SEAT VENTILATION/HEAT for the front seats.
App Buttons along the bottom are completely different.
Audio Features doesn't seem to recognize the HK system (no surround on/off choice).
MOST OF THE TRUCKS FEATURES ARE NO LONGER AVAILABLE ON THE APP MENUS. Even most of the SETTINGS MENUS ARE BLANK.
There HAS TO BE A WAY TO DISABLE THE SOS/ASSISTANCE BUTTONS - since they don't frikkin work ANYWAYS. Why did they have to put them SO CLOSE TO OTHER BUTTONS - they should have been in a section APART FROM the buttons used on a daily basis.
At any rate - I guess it's OFF TO THE DEALER IN THE MORNING.
I made TWO CALLS to UConnect. One nice lady put me on hold - ONLY TO HANG UP ON ME. She told me, you have to drive the truck for a few miles (no idea how many constituted "a few") and the truck would recognize all the installed features.
The second woman told me, ANY TIME THE BATTERY IS DISCONNECTED - THE DEALER HAS TO SETUP THE HEAD UNIT AGAIN. And no idea if THEY WILL CHARGE ME FOR IT (which will pizz me off EVEN MORE).
So - is there a way to disable the SOS/Assist feature (up to and INCLUDING DISCONNECTING THE FRIKKIN BUTTONS)?
Or - is there a way to REBOOT THE SYSTEM (short of disconnecting the battery or fuse) to disconnect the SOS Call (which DOESN'T WORK ANYWAYS).
Siruis Guardian App is USELESS - if this is a part of it - I'd just as soon blow off my "free trial" and SHUT IT DOWN.
I'm pretty much LIVID. Should have stuck with FORD OR CHEVY - even though NONE of their offerings are nearly as nice or have as rich an option set as the RAM. He11 - should have just gotten another honda pilot (for $25K less), at least I had ZERO ISSUES in 90K miles with my last one.
/end rant
Rick
Any suggestions would be welcome.
/end rant
Rick
