Hey. I've been having a recurring issue with a P0507 code, higher than normal idle. It doesn't cause any drivability issues, but it does trigger a permanent check engine light and may be causing a problem with the start/stop system becoming unavailable under certain idle conditions.
I've brought it in once before, and the technician said he tightened a clamp, but that did not fix the issue. I'm bringing it in to a different service department on Friday and before I do, I wanted to see if anyone here has encountered this code and what the resolution was.
2020 Laramie 1500, V8 E-Torque
Thanks for the infos!
