Help with leveling setup
alecw
So I am new to this whole modifying suspension thing. So I am just trying to level the front with the back and to allow me to fit 275/65/20s.
I have seen some talk about using 5100s and upper control arms. Was wondering I needed front and back or anything else. Feel free to completely correct me. Just want a reliable and quality setup.
thanks ahead of time
texasvolfan15
You don’t need to get new UCA if you are just doing a level in the front, UCA are required when you do something more like the mopar 2 inch lift, ready lift, or hacking your own way to it.
I’d suggest just getting bilstein 5100s adjustable front shocks, at setting 4-6 depending on how much rake you want and call it a day. You’ll be able to fit the tire size you want
Doc33
I'm using 275/65/20 with the Bilstein shocks on setting 5. The rear is stock but I went with the mopar UCA as a personal choice. Have a 1/2 inch rake and happy with this set up
alecw
Are you using LT tires or no? and thanks for your help.
Doc33
Pic
cjpofd
California
Do you have a full side view pic you can post? I'm thinking of going the same route.
