Help with codes
UnclJim
Long Island
2022 Rebel GT w/ eTorque.Truck is iintermitently chiming on start up along with head or fog flashing (no it’s not when I’m turning) get a flash on gauge panel of AEB not working pulled codes the duration of this gets longer with each start up possible bad battery or generator ? I have added upfitter switches battery voltage will range from 13.2- 13.8
Codes;
U0010
U113B
B17C0
B168E
stevj
On a clear day, I can see Seattle from my house.
U0010 - Medium Speed CAN Communication Bus
Possibilities:
  • CAN IHS BUS CIRCUIT OPEN OR HIGH RESISTANCE
  • CAN IHS BUS CIRCUIT SHORTED TO GROUND
  • CAN IHS BUS CIRCUIT SHORTED TO ANOTHER CIRCUIT
  • CAN IHS RELATED ECU
  • CAN IHS RELATED STAR CONNECTOR (IF EQUIPPED)
  • CAN IHS RELATED SPLICE BLOCK CONNECTOR (IF EQUIPPED)
U113B - Lost Communication With Switch Bank Module
Possibilities:
  • FUSED B(+) CIRCUIT OPEN OR SHORTED TO GROUND (OPEN FUSE)
  • GROUND CIRCUIT OPEN
  • LIN BUS CIRCUIT OPEN
  • SWITCH BANK MODULE
Other codes do not cross.
Steve
UnclJim
Long Island
Possibilities:
Possibilities:
Steve
Thanks, mostly wondering if this can be a battery issue or not. One code for switches one code for fogs one’s an airbag ( no airbag light tho) one who knows seems varied and I know my magnum thru strange unrelated codes when battery was going wonky
