brental1
I have a 2022 BH with Level 1 EQ. Last year, I swapped in Heat/Vent Front Seats and Heated Steering Wheel. They didn't require programming to get the hard buttons to work. I have now programmed them with Alfa and the soft buttons now appear on the display.
I just swapped in Heat/Vent Rear seats. I programmed several changes with Alfa and the Right switch (both heat and vent) work. However, the Left switch does nothing. I'm trying to diagnose the Left Switch with Alfa. How/can I do this?
The dropdowns for all the LIN options show 22 options; but none of them seem to be heat/vent switches. Unless I don't understand some of the acronyms.
When I choose Display LIN Part Numbers and Serial Numbers, I get "Failed for Undefined Reason".
I'm afraid to Reset LIN ECU.
Appreciate any input. Brent
