mikejerseyisme2010
- Mar 3, 2019
There are a few possibilities.Help! 3.5 inch Readylift installed last week and its making a clunky noise on the drivers side. Going to take it back to the installer but anyone else have issues or ideas?? Thanks!
Thank you Sir!! Will have them check itThere are a few possibilities.
- The nut on top of the strut assembly is not tight
- The sway bar/end links were not tightened back up
- There is a tsb for the front body mounts and one of the symptoms of the issue is a clunking sound particularly on the front driver side
Submitted my post too soon, have edited it. Good lucking truck by the way.Thank you Sir!! Will have them check it
Thanks again!Submitted my post too soon, have edited it. Good lucking truck by the way.
I had the same exact scenario with my Mopar 2” lift. I tightened the sway bar end link then ended up installing a new one just to verify the ball joint wasn’t shot (they are cheap it was only $20 or so). The clink has been going on since I installed about 6 months ago and was driving me crazy. I couldn’t reproduce it on demand it would just randomly make the noise. After 3 days at the dealer this week they claim the nut on top of the strut assembly wasn’t tightened down all the way as mentioned above. Have not gotten the truck back bc they’re waiting on a rear window to come in to replace the cracked surround issue I had and water leaking. Will verify next week when I get it back if that fixed the clunk or notHelp! 3.5 inch Readylift installed last week and its making a clunky noise on the drivers side. Going to take it back to the installer but anyone else have issues or ideas?? Thanks!
Thank you!! Will suggest the top nutI had the same exact scenario with my Mopar 2” lift. I tightened the sway bar end link then ended up installing a new one just to verify the ball joint wasn’t shot (they are cheap it was only $20 or so). The clink has been going on since I installed about 6 months ago and was driving me crazy. I couldn’t reproduce it on demand it would just randomly make the noise. After 3 days at the dealer this week they claim the nut on top of the strut assembly wasn’t tightened down all the way as mentioned above. Have not gotten the truck back bc they’re waiting on a rear window to come in to replace the cracked surround issue I had and water leaking. Will verify next week when I get it back if that fixed the clunk or not
