So this is recommend by the dealer if they put it on? Would you have done anything different now that you been reading this site? A different brand?I have this kit, but without the uca's. They're still stock. This is what the dealer installed when I requested a 2" level when I purchased the truck 6 months ago. I've learned a lot since then by reading this site. Most say the factory uca's will work fine at 2" maximum lift. Anything more than that creates stepper angles and stress, requiring a different uca.
Before reading on this forum I didn't know anything about lifts and levels. Just knew I wanted to take out the rake. The Readylift is what the dealer chose. We didn't have any discussion of options.So this is recommend by the dealer if they put it on? Would you have done anything different now that you been reading this site? A different brand?
The body roll is because you lifted it, not from the spacers. You'd have that with Bilsteins too. If you want to get rid of that a Hellwig rear sway bar will tighten the body roll up.Before reading on this forum I didn't know anything about lifts and levels. Just knew I wanted to take out the rake. The Readylift is what the dealer chose. We didn't have any discussion of options.
After reading this site, I would definitely be checking into the Bilstein adjustable shocks as an alternative.
As far as ride quality, I only had it for a week before the level was installed, so not a lot to compare to. The only thing I can say is I feel like the truck may have some additional side to side lean on turns that it maybe didn't have at stock height. Don't know if that would be any different with the Bilsteins. To me that's just physics and makes sense when the center of gravity is raised.
I got Motofab 2" spacers for $65, installed myself. You can get the OEM UCA's that come with the MOPAR 2" kit for around $100 I think. Their part numbers are all over the forum.So this is recommend by the dealer if they put it on? Would you have done anything different now that you been reading this site? A different brand?
Ya that's my thought too. I've been thinking about the hellwig. Sounds like You're saying that even though the body roll is caused by rasing the center of gravity in the front, adding the hellwig in the rear will help with the body roll?The body roll is because you lifted it, not from the spacers. You'd have that with Bilsteins too. If you want to get rid of that a Hellwig rear sway bar will tighten the body roll up.
It won't completely eliminate it, but it'll reduce it because it anchors the body to the frame better. Just look up Hellwig on here, and you'll see people talking about it. I personally don't have it, but I've been driving lifted trucks for so long that I'm used to the roll.Ya that's my thought too. I've been thinking about the hellwig. Sounds like You're saying that even though the body roll is caused by rasing the center of gravity in the front, adding the hellwig in the rear will help with the body roll?
