Help? Hey guys, I have a 2019 Ram, 1500 V8. Hemi Laramie starting issues.
I went to start my Ram 1500. This morning with the auto start. When I came out the house i noticed, the truck did not start, so sat in the truck hit the brake and the start button. It does everything as if it's going to start but does not do anything at all. Doesn't crank over or nothing? Any ideas or experience with this type of issue
Javi
No noise=no starter. Bang on it or replace it.
My 2022's starter crapped out at 36k miles. Apparently it's a thing with 2019-2022's. Hell if I know. After 6 months of f'n around with it not starting (replaced battery, cleaned body grounds), I finally changed my starter and it solved my problem.
THIS^^^ The exact same thing happened with mine.
Its the original starter, I ordered a new starter from the dealership
Good call. Curious, did you try the hammer trick to verify?
Now get ready for a 6 hour+ ordeal...unless you have a car lift. If it's the original battery, I would change it. Also clean the body ground on the driver's side fender up near the hood strut. Good luck!
