I drive a 2021 1500 limited with the stock air suspension. I just got an alignment from a local shop (not a dealer as they are 30+ miles away). I showed them how to put the truck in alignment mode before leaving. I assume they did this but can't verify. They returned my truck with the ABS, Trailer Brake and Stability Control Lights on and warning messages in my message center. They said they tried to clear them, but they would not clear from memory. They assumed after driving they would reset themselves. They have not. I went home and removed the battery ground for 20+ minutes to hard start the systems, but the warnings persist. Any information on how to get these systems up a running again either by myself or the shop would be appreciated. Also, I needed a new battery and had it replaced. I had the check engine light come on when the voltage was low, but it went out after driving for a while on the old battery. The light is still on. Is it due to the brake issues or the battery?
Thanks in advance,
MDNT2021
Thanks in advance,
MDNT2021
