Bctexascrazy1
- Mar 25, 2021
For those of you that ordered the hellwig on your lifted level trucks, did you order it as the kit with the links? It says can be used with 2-4” lift. So technically since I have the ORP springs and I added a 1” spacer to the rear I have 2” of lift.. so should I order the kit with the links or just be ok with the sway bar? I have the 5100’s in the front and rear and the rear just feels loose at times and want to upgrade to the hellwig cause everyone swears by it?
