Klute
I have read the install instructions on-line. Does adding it require a software flash (or something like that)? The instructions I found didn't mention it.
Thanks!
Thanks!
Thank you! How much did they charge you for the flash? Did you buy the hardware from them? Did you have any problems after you installed and before it was flashed?Yes, once installed you will need to go to the dealer to have the flash and applications added.
I did this and it was seamless.
Or you can buy the stuff to do it yourself for less than what the dealer will charge youYes, once installed you will need to go to the dealer to have the flash and applications added.
